DJI mini 3 pro Zoom does not work
9215 17 2022-12-26
fans82a69807
Flight distance : 49583 ft
DJI mini 3 pro Zoom does not work. I have it at 4k 30fps setting. The zoom does not move when dialing the right wheel. No matter what I do, or which setting. Anybody can help me?
2022-12-26
fatsharkaunz
Pretty sure the zoom function will only work fully in the lower res video settings , try changing it to 1080p to test.Digital video zoom at up to 2x is availiable in 4K, 3x in 2.7K, and 4x in full HD
Also go into the settings and then custom settings for the RC to see if the dial is set for zoom function
2022-12-26
DJI Tony
Hi there. Thanks for reaching out. You may consider checking the suggestion we have posted in this link. Should you have further concerns, please reach back here at DJI Forum. Thank you.
2022-12-26
stonedroned
fatsharkaunz Posted at 12-26 13:22
Put Video on 1080 and checked dial - wich is set to zoom function. Still does not work
2022-12-27
ians9994
Flight distance : 158996 ft
I've got exactly the same issue. It will only zoom in using photo mode but any of the resolution options when shooting video the zoom wheel will not work it seems to have only started happening after the v01.00.0450 update.
2022-12-28
stonedroned
ians9994 Posted at 12-28 08:57
I made an update yesterday and it worked again. Maybe you could try the most recent update from yesterday
2022-12-28
primeshooter
Flight distance : 1433114 ft
There was another update yesterday?
2022-12-28
stonedroned
primeshooter Posted at 12-28 12:38
Actually I am not sure why my drone wanted an update after searching for updates since I updated one day before. The Version it shows in the controller is 01.00.0450 for the aircraft and 01.02.0200 for the RC. Anyway zoom works in Foto as well as in Video mode now. Maybe there was an ulabled new version? Anyway I thinik it does not hurt to check again for updates just in case.
2022-12-29
DAFlys
stonedroned Posted at 12-29 04:11
Had you updated all your batteries when you did the firmware upgrade,    each battery can prompt to be re updated which often confuses people into thinking they installed yet another update
2022-12-29
stonedroned
DAFlys Posted at 12-29 04:17
Oh. I did not even know about that. No I did not update all my batteries, this could be why it wanted the second update. Did you find a solution for your Zoom issue?
2022-12-29
DAFlys
stonedroned Posted at 12-29 04:23
My zoom works fine.
2022-12-29
djiuser_s138xAaH5lbs
Flight distance : 226864 ft
Hi. When I take off there is a 20 second zoom delay
What's happening ?
2023-3-19
DJI Tony
djiuser_s138xAaH5lbs Posted at 3-19 12:01
What's happening ?
Hi there. We have responded to your concern in this post. Thank you.
2023-3-19
djiuser_OMkVQDGLbZyQ
Flight distance : 269531 ft
I have the same problem, no zoom in video mode. Aircraft firmware 00.01.0450 Rc firmware 01.02.0400.
I've checked everything and still the same :/
2023-3-26
Mirek_62
Flight distance : 45171 ft
Czechia
djiuser_OMkVQDGLbZyQ Posted at 3-26 02:58
What video mode you have set. Digital zoom can only be used in certain modes.
2023-3-26
Mirek_62 Posted at 3-26 04:11
Standard video shooting.
2023-3-26
Mirek_62
Czechia
Doesn't it work through the control dial and the screen?
Have you tried 1080 resolution?
2023-3-26
Drone.Hunter
Flight distance : 4537612 ft
Kazakhstan
4k@60 - not zoom, 4k@30 - 2x zoom
2023-3-26
