djiuser_YQmZ6Kfu6Nem
Flight distance : 708307 ft
Philippines
Yaros1 Posted at 1-31 06:57
I don't own a Mini 2 and can't tell you for sure. However, I might have an idea on how to solve those incompatible module errors.
Download DJI Assistant for Consumer Drones here and plug in your drone to your PC using a USB cable, turn it on, and make sure you are on the latest firmware, if not then update, repeat the same but changing the batteries in the drone, all of them have to have the latest firmware. Then plug in your controller to your PC, using a USB cable, but plugging in the Type C part of the cable to the bottom port of the controller, the one used for charging, not the top one. Then go into the same software (DJI Assistant) and update the firmware if possible.
thank you yaros. i already have this and theres no rollback as ive read the latest firmwares for the mini 2 are no longer available for rollback. the latest firmware has rendered incompatile all the modules. searching for latest 2023 knowledge base on how to hack this or worse wait until another firmware update is released for mini 2. i have no geofencing limits f thats the reason for latest updates, i can follow by the rules. the problem is bugs may have cause the grounding of my drone
