trica de
Flight distance : 1062090 ft
CoreyFPV Posted at 12-29 23:39
I know it's probably a dumb question but have you checked all the wiring etc ? What board is it connected to and are the wires soldered to the correct pads ? If the cables do not match as they are in the user manual, it won't work correctly - Page 5 of the 03 Air Unit user manual. I also found that the cable that comes with the 03 unit does not plug and play direct into a T-Motor F7 45a mini stack, as the cables or ports on the socket of the board are incorrect. I had to snip the end off the cable and solder to the pads on the board. Auto record on take-off worked perfectly.
I had to change the rx / tx cables to get osd working that’s all. I do not use the dji control so the 2 cables for the receiver are not connected.
My board called iflight blitz 1.1 mini f7.
Crossfire is connected to the right UART and DJI is connected on the left - big port ! But only 4 cables. Power, GND, RX and TX. If RX and TX would be worng my OSD would not work.
