Bashy
Flight distance : 2354357 ft
AntonioTech Posted at 1-4 12:37
Thanks for your thoughts! However, you know what they say: the presupposions are the cause of many F-UPs and misunderstandings.
Long before I bought the M3P, I had gone several times through the manual, let alone the videos I watched on Youtube. One thing tricked me, though, and I didn't believe that the range was such an issue but it was and still is.
But you now know that the range isn't an issue if simple steps are taken, CE is most certainly far lower over urban than what FCC is, so around 300m urban when not applying what you've learnt is pretty good.
RE Mavic 3, as DB pointed, there are far fewer owners in comparison due to the cost, also as DB stated, they are probably more experienced, but one major point will be that many will be flying it within VLOS due to using it for commercial work so probably not venturing much further than 300m anyway. Then there is the matter of the RC, i bet there's a good handful using the RC Pro with it, the adjustable antennas will make a difference for sure.
2 other points, but i might be wrong on this one, the antenna placement could be different, are they in the legs (vertical) as opposed to the arms (horizontal), and it is O3+ transmission as opposed to O3
Comparing the 2 is like chalk and chees really. |
