DJI Wanda
Hello, there. Sorry for the inconvenience. For Consumer Drones, the near-ground altitude is the combined altitude of the barometer and GPS.
The barometer is easily affected by unstable low air pressure, air temperature and other factors. This can lead to a deviation in the barometer metered altitude.
The GPS altitude is also affected by accuracy, which can lead to an error with the near-ground altitude. However, negative altitude display will not affect flight performances.
Suggstions for narrowing altitude display errors
1. Land the aircraft and take off again. At this point, the flight controller will recalculate the aircraft altitude relative to the takeoff point. This can improve the display accuracy.
2. Do not fly the aircraft forcedly in a vertical direction (Repeated rapid ascending and descending will lead to a larger altitude error). This can improve the display accuracy. |
