LV_Forestry
Flight distance : 4726654 ft
Latvia
Hi,
In Oblique mode, you are right, the application will automatically generate 5 flight plans. North South East West and Center. But you can change the angle in the setting menu.
-> Course Angle
Another method, (To my knowledge, this one works only with P1) create a Mapping flight plan instead of Oblique, check the Smart oblique option and choose your angle. Then you can do the same thing for the other heading, add 90 degrees.
The camera swaps its orientation during the flight between 45 and 90 degrees to make a semblance of oblique (in only 1 flight plan instead of 5 if you decide to do it on one heading).
Attention! it is a little different from the pure oblique mode. But in principle it works well too.
It all depends on the result you want to achieve.
Good luck
