"Chapters" are a problem
1175 39 1-15 17:32
FwB
When will we be able to turn off video chapters?  The transition from one chapter to another is not fluid on the Action 3!  If I am talking it cuts me out and transistions really harshly.  I would almost return this camera if it didn't excel with everything else it does.  It's going to cause me to lose footage at some point or make some of my videos not make sense (because I have to edit out what I was saying).  I am one of the few that records for hours and has abolustly no control with what is going on.  I could be talking and doing stuff at any moment in time.  Old discontuned Sony action cameras were the only ones I know of that didnt have this chapter nonsense.  The GoPro's do it too and their transistion isnt the greatest either (but more workable than DJI's).
Currently this is my only complaint on this camera.  Allow us to toggle chapters on and off and this will be THE action camera to get.
1-15 17:32
DJI Gamora
Hi, FwB. Thank you for reaching out and we're sorry for the inconvenience. Video splitting is made in order to avoid errors resulting from files being too large, the files will split when the capacity exceeds 4GB. But I will take it as a suggestion of yours and will forward it to our designated team for attention. All significant suggestions will be implemented after the evaluation of our relevant team. For the latest updates please stay tuned to our DJI official website at ( www.dji.com ). Thank you for your support.
1-15 18:54
osmonauta
You need to use the right tools for the job. Big editing programs like DaVinci, Premiere, iMovie, etc are not always the right tools.
You need to first join all the file segments using just a data copy, without any compression. Then you can take the result to an editing program and edit away.
Use LosslessCut to join the segments. It is a GUI wrapper for ffmpeg. It is working flawlessly and the result doesn't skip neither audio nor video frames.
https://forum.dji.com/forum.php?mod=viewthread&tid=281755
1-15 19:35
johansenfoto
Flight distance : 1173379 ft
Norway
From what I did understand, you mean it make a bunch of 4GB files?
If so, then Insta360 ONE RS would be a great camera since it have no limit on filesize.
It all have to do with which filesystem on the card have been formatted in.
1-16 01:05
Fishycomics
agree with both Johansefoto and DJIGamora
  https://forum.dji.com/thread-231351-1-1.html
1-16 03:56
osmonauta
johansenfoto Posted at 1-16 01:05
Generally, yes, it has to do with the file system, however, in this case, if you format the card in the camera and then check it on the computer, you will see that the camera does format it as an exFAT. So technically the file system would support huge files. So I believe it was DJI’s decision to still split them.
I had a different camera before that was using FAT32. And in that case every segment was split EXACTLY at the same size (4.0-something gigabyte). With the Action 3, however, the split size varies. Some files are 3.78, some are 3.8, etc. (...in case of 1080 footage)
1-16 05:00
FwB
Having chaptering because of possible errors is admitting fault.  It's basically saying your camera is faulty.  Sony mirrorless cameras do not have this issue.  Their old and discontinued action cameras did not have that issue.  You could record for hours and end up with a 100gb file if you wanted to.  You can record with the Action 3 for hours and get 100gb worth of data but its a hundred files.  Its a confusing mess and using another program to stitch them together hurts when you have only so much time to edit.
If a $14,000 cinema camera and a $150 action camera can record one long file up to the size of the SD card why can't DJI?
As a side note, I would never ask GoPro for this feature because of how faulty their products are.
1-16 16:32
Fishycomics
IMO" lose the whole file, or just a chapter when the camera crashes? Gopro has goprolabs for the larger chapters, and they have a   crash program built in if it crashes. think DJI crashes its done
1-16 16:54
FwB
Fishycomics Posted at 1-16 16:54
So the camera is flawed?  Sony does not chapter.  Why is this even an issue?
1-17 04:11
Fishycomics
FwB Posted at 1-17 04:11
I hear what you're saying .  flawed, no, just chapters are what  is offered and no choice for us to choose.
1-17 04:53
FwB
Fishycomics Posted at 1-17 04:53
I will admit I have asked for this before in the past.  I get the same answers.  The answer saying "losing a chapter is better than losing the whole video" is a wrong answer too.  If there is something with the recording or SD card you will lose all the chapters!  I had this happen with a GoPro.  I was recording for over an hour and it only gave me 2 minutes of the first "chapter" causing me to lose valuable footage!
There is no reason in this day and age for a video to be cut up.  Allow us to control the length and size of the video.  Allow us to toggle chaptering off!  Sony did this 10 years ago (and still does this).  One video recording, one file.
1-17 06:56
Fishycomics
seems its not much of an interest for DJI as well others here.
1-17 15:49
4wd
Flight distance : 545817 ft
Fishycomics Posted at 1-17 15:49
On one of the facebook groups someone claims to be able to switch it on and off in basic settings but won't publicly say how.
I don't believe it, nothing in the settings has any bearing on chapter length.
1-19 02:36
Fishycomics
4wd Posted at 1-19 02:36
thank you  but ther will be no  removal of chapters unless DJI does a firmware update and that will not be any time soon.  was noted to get a Insta by someone or a gopro and use goprolabs
1-19 03:53
Iancraig10
There is one camera that I can’t remember which, that does ask for max file length but not the Action. Not a lot you can do to get around it really.
1-19 05:07
4wd
Iancraig10 Posted at 1-19 05:07
It doesn't bother me anyway the Mini 3 pro and mavics before it were the same.
1-19 09:36
Iancraig10
It does limit sports and drone people though. The only option is to drop down to 1080p so more time is available for videoing or do everything in quick bursts!
It’s never affected me since I never take long clips but I can see that could be a real pain for certain users.
1-19 10:55
Fishycomics
WHen I owned a  JVC camcorder, I was able to  record   one file for the whole tape and if it ripped I could sply repair it. today its all digital and guess  editing all the chapters is added work today.
1-19 10:59
Iancraig10
I can still do the same with my Sony camcorders and mirrorless cameras. Canon limit you to just 30 minutes a pop!
My first film video camera actually was a film camera and did 4 minutes max!! No sound.  It had to be shown via a projector, with me playing live music for them, spliced together......
Then I went posh to digital video tapes. 30 minutes, 45 minutes and 1 hour cartidge tapes. Pure luxury.
I also did a lot of slides and printed my own cibrachrome prints from them in the attic!
1-19 11:03
FwB
Tell the fish to bite during the short bursts lol...  Being able to turn off chapters is a pretty big deal.  Please DJI allow this.
1-19 11:38
4wd
"someone claims to be able to switch it on and off in basic settings"
I honestly wonder if he is confused by the settings for screen off after x minutes recording.
- but dare not suggest it as he is bizarrely cantankerous and defensive.
If you know a way to stop chapters why would you not just describe it - we will only say does not work or wow it works.
1-19 11:39
Iancraig10
FwB Posted at 1-19 11:38
Do you use the ‘loop’ feature for fishing? Or is it better to just leave the camera rolling?
I was thinking about going fishing when the weather improves and take the camera. I was think that maybe I’d let the loop roll…….
I live near the river Eden and caught a big Chubb on a lure last year and thought I might go back and have another go with my camera.
1-19 12:04
Fishycomics
All DJI has to do is offer a command to the firmware and done.
Did you reach out to  one of their departments rather the support forum where its more a   trouble with the camera and a lot of check the official firmware, DJI did take  peoples comments over the  last three years and here we are today asking about the same things that never went through.
https://www.dji.com/contact?site=brandsite&from=footer
1-19 12:28
osmonauta
"...using another program to stitch them together hurts when you have only so much time to edit..."
The program doesn't do recompression (unlike any other editing program) so it literally takes a few seconds to join the file segments. If you don't have 30 seconds to join hundred gigs of segments (or just 5-10 seconds when you join just tens of gigs), then I'd say it's more of a lifestyle issue as oppposed to file segmentation :-)
1-19 19:06
Iancraig10
The loop can be set to an hour or longer. At least that’s my understanding.
1-20 00:16
4wd
osmonauta Posted at 1-19 19:06
It isn't even that difficult if you sort them by name in Premiere you can select all and drag across to timeline like one file.
It takes no additional time at all if that is somehow a problem.
I often use mine as dashcam and usually do that, then cut out what I don't want to use.
1-20 02:17
Fishycomics
the days of MS-DOS
CD (Enter) copy/b 0. mp4+1. mp4+2.
1-20 04:09
osmonauta
Fishycomics Posted at 1-20 04:09
the days of MS-DOS
Many people prefer to work with the Terminal to do things even today.
Many video editing programs or media viewers use FFmpeg for their encoding/decoding function. FFmpeg also has an insane amount of terminal commands that you can use and these apps simply a GUI for the underlying terminal commands.
1-20 04:20
Fishycomics
and many like for  chapters to g o away
1-20 04:31
brettb3
Chapters a issue?
1-31 10:24
FwB
Yes a huge issue for anyone recording an actual video.  I want to capture action.  Sometimes that action takes up to an hour to happen.  Also if you are on a motorcycle  and vlog for more than X minutes you end up with multiple files.  Imagine what insanity a two hour ride would be with the amount of small clips created by said trip.  Sony does one file per recording.  Why cant we get the CHOICE to do that?  If you like chapters than you can keep it that way.
1-31 11:57
johansenfoto
Norway
Not sure if chapters is the right word since it split files in same size/length.
But the problem with splitting files is that you get a sound gap between each clips no matter how fast the card is.
I see it many times when recording for longer times, but usually it haven't been a problem, but my latest video it was quite noticable.
1-31 14:41
osmonauta
Hungary
johansenfoto Posted at 1-31 14:41
Have you tried this?
https://forum.dji.com/forum.php? ... D781%26typeid%3D781
When I do a 1.5 - 2 hour bike trip, I end up with multiple segments. So far I never had a gap.
1-31 16:38
FwB
osmonauta Posted at 1-31 16:38
https://forum.dji.com/forum.php?mod=viewthread&tid=281755&extra=page%3D3%26filter%3Dtypeid%26typeid%3D781%26typeid%3D781
That is a 3rd party app.  We want the camera to do it for us so its one less step in post.  Other cameras do this including older action cameras.
The Action 3 has more than this as a problem so I may be moving back to my GoPro Hero 8.  Its the only camera that works for me (except it chapters too, at least the cuts are not as bad as the Action 3).  I had high hopes for this camera.  Its camera number 14 for me that I've tried to replace my Hero 8 with.
1-31 18:49
DJI-ytao
DJI R&D Squad
Flight distance : 1209413 ft
Hi FwB.
would u plz let me know the editing tool u are using?
1-31 20:19
johansenfoto
Norway
I doubt it can fix clips that lack sound at beginning or end of a clip
1-31 23:47
osmonauta
johansenfoto Posted at 1-31 23:47
You said it was “between” clips, which would indicate a joining problem. If the audio is missing from the beginning/end of the clips, that sounds like a different issue.
2-1 01:31
Fishycomics
I like  the chapters but I do not like the THM and secondary files, if DJI has like gopro GoProlabs, its time they start one here. this camera has potential only if it works right for some people.
2-1 03:44
FwB
DJI-ytao Posted at 1-31 20:19
Hi FwB.
DaVinci Resolve.  I rather be able to record one file than 20 in a single recording.
2-1 07:48
johansenfoto
Norway
osmonauta Posted at 2-1 01:31
That is standard problem with gopro also
2-1 10:53
