JJB*
Flight distance : 12260774 ft
Hi,
Always a ittle difficult to see part of a flight on video, finding out wich part of the video = log data.
But flying only with forward stick (see the chart of your flight), your Mini3pro kept his heading within 0.2 degree. So straight flight line, heading 333.5 all the time. (first green box)
Move line same (GPS data) same as heading drone, but after relasing stick (speed from 5.9 m/s to zero) drone moved away from heading line.Kind of normal behaviour if there is some wind blowing on the drone, drone needs to get into stable hover with same heading as before, heading might vary during relasing all sticks to zero.
First green box, after releasing forward stick some yaw inut was given, drone follows.
For flying a perfect straight line, to a imaginairy straight line on the ground, you need zero wind.
cheers
JJB
