High-Bright Remote Monitor blank screen
navarrorenato
Brazil
Hello everyone,
We was using normally the monitor in the recording jobs and now, out o the blue the screen is gray, with powered lcd/led light scren, but not showing the system or camera image.
We already changed de battery, try to update de firmware downgrading the version to V01.05.0200, set back to the lastest version V01.05.0300, and the problem still happening.
Attached is a photo of our frustration with less than 2 months purchased :/
DJI High-Bright Remote Monitor
Has anyone already seen this problem??
Tks
2023-1-19
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out and we're deeply sorry for the inconvenience. Can you please try to turn off the display, reinstall the battery and then turn it on and check whether the factory settings can be restored and the screen displayed normally? If the issue persists, please record a complete video of the camera connection and operation process for us to check. Please keep us posted. Thank you.
2023-1-20
navarrorenato
Brazil
Thank you very much for the anwser and the tips.
We did that steps again without sucess.
A new information, the screen is blank but the SDI and HDMI Output have image.
Also when plug the hdmi on right input nothing still happens.
Follow the videos:
Monitor 01
https://youtube.com/shorts/wqGZl7u4B0E?feature=share
Monitor 02
https://youtube.com/shorts/cd6J_0wGZy4?feature=share
Monitor 03
https://youtube.com/shorts/nbyyCI2Pjp4?feature=share
2023-1-20
navarrorenato
Brazil
Anyone have a sugestion?
2023-1-25
DJI Paladin
navarrorenato Posted at 1-20 10:57
Hi there. Sorry for the late response and for this unpleasant experience. In this case, I'm afraid that you may consider sending the unit in for a proper diagnosis. You can contact our support team to start up a ticket at https://www.dji.com/support . Also, the warranty can be applied depending on the outcome of the damage assessment including the warranty period of your unit. Thank you for your kind and understanding.
2023-3-14
