Mzp
ZmoothOperator Posted at 1-20 15:17
How do you export? The arrow at top right? You should have choices there. "Export File" is default, and you can then modify file types in the Settings tab. Chose Mastering in the drop down menu.
But I use Compressor. If you intend to work quite a bit in Final Cut, I'd suggest getting Compressor. And you can make presets with your favourite settings, and have them show up in the Final Cut export menu.
Hi ZmoothOperator,
I am also using Compressor (had to buy it). I also setup presets with it HEVC 10 bit HLG Dolby Vision or just HEVC 10 bit , but unfortunately I can't seem to find anywhere in settings of Compressor or in Final Cut Pro an option where I can select the bit rate manually. Thank you for your suggestion ZmoothOperator, I will try to dig around more, thinking also to try ProRes export and then transcode via Handbrake. Will keep looking , thank you for your suggestion.
Take care, Mike. |
