DJ DJ
snowcatxx87 Posted at 2-21 07:50
Then why does my 10 year old GoPro4 with USB mic (no adapter, no dac, straight in to the unit) work perfectly fine with the GoPros automatic Gain?
Obviously GoPro went the other way for the Gopro4. You can transmit anlogue audio via USB-C or you can connect a digital audio device that processes the signal and transmits the results as digital data.
Analogue audio can simply be controlled by an internal DAC, so gain control, limiting and processing is managed there. The GoPro4 seems to have one and uses analogue audio signals, that can be dampened before processing to avoid clipping (just another guess).
The DJI Action 3 obviously does not have a DAC (USB-C adapters without DAC don't work) and relies on an external one, same as GoPro from the GoPro5 upwards, hence the MediaMod or their dedicated USB-C Adapter.
So the conversion is done in the external device. As I said, I don't know for shure, if it is possible to control a simple external sound device via USB-C without drivers - an embedded system like an action cam could only use standardized commands.
If the Action 3 can only process the already digitized signal from the DAC, clipping that has already happened cannot be fixed afterwards.
You can boost a signal, that is too low, though, so positive gain makes sense, even if you amplify background noise that way.
That's why DJI should offer something like GoPro does. A dedicated USB-C audio-adapter could easily be designed to be controlled by the internal controls of the camera or could even provide automatic gain optionally.
But they have something. The DJI Mics seems to offer just that. They are just a bit pricey if you don't need a wireless transmitter...
And don't forget - this is a lucky guess as DJI simply does not provide that info...
