Blondin555
Good afternoon. After trying to install the update, it failed. I tried to update again, but also failed. [19 00] Firmware upgrade finish failed (step = 2, err = 0x08) Is there any solution to this problem?I tried to do it upgrate and downgrate,the result is the same.
[00012092]Packet [C:\P3S_FW_V01.09.0060.bin] resumed, card sn [0x00002b0a].
[00012370]Packet vlink 01.09.0060 <-> 01.08.0080.
[00012468]Record vlink 00.00.0000 <-> 00.00.0000 (flow = 0).
[00012564]Version checking[2]...
[00012692][03 05][00] v34.2.0.9 -> v34.2.0.9
[00012827][03 06][00] v2.2.6.8 -> v2.4.20.18 need upgrade.
[00012950][04 00][00] v1.38.0.0 -> v1.44.0.0 need upgrade.
[00013112][11 00][00] v1.6.0.0 -> v1.8.0.0 need upgrade.
[00013274][11 01][00] v1.6.0.0 -> v2.0.0.33, firmware v1.6.0.0 not support.
[00013370][11 01][00] v1.6.0.0 -> v2.0.0.33
[00013503][12 00][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013646][12 01][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013826][12 02][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00013962][12 03][00] v1.8.0.0 -> v1.10.0.0 need upgrade.
[00014053][15 00][00] v1.1.2.0 -> v1.1.2.0
[00014197][17 00][00] v1.1.1.7 -> v1.1.1.7
[00014377][17 01][00] v1.0.2.7 -> v1.0.2.7
[00014504][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00014597][01 00][05] v1.23.4920 -> v1.23.4920
[00014696][01 01][00] v1.14.3090 -> v1.23.4920 need upgrade
[00014904][09 00][00] v1.7.0.3 -> v3.0.0.10 need upgrade.
[00015004]Done.
[00015094]Firmware upgrading[2]...
[00015382][01 01] Firmware upgrade start...
[00045831][01 01] Firmware upgrade finished successfully.
[00045950][12 00] Firmware upgrade start...
[00119718][12 00] Firmware upgrade finished successfully.
[00119834][12 01] Firmware upgrade start...
[00184944][12 01] Firmware upgrade finished successfully.
[00185060][12 02] Firmware upgrade start...
[00247111][12 02] Firmware upgrade finished successfully.
[00247236][12 03] Firmware upgrade start...
[00310379][12 03] Firmware upgrade finished successfully.
[00310494][11 00] Firmware upgrade start...
[00357922][11 00] Firmware upgrade finished successfully.
[00358358][03 06] Firmware upgrade start...
[00720261][03 06] Firmware upgrade finished successfully.
[00724206][19 00] Firmware upgrade start...
[00754900][19 00] Firmware upgrade finish failed (step = 2, err = 0x08).
[00785035][09 00] Firmware upgrade start...
[00837140][09 00] Firmware upgrade finished successfully.
[00837275][04 00] Firmware upgrade start...
[00897163][04 00] Firmware upgrade finished successfully.
[00897264]Done.
[00897362]Version checking[3]...
[00897502][03 05][00] v34.2.0.9 -> v34.2.0.9
[00897642][03 06][05] v2.4.20.18 -> v2.4.20.18
[00897786][04 00][05] v1.44.0.0 -> v1.44.0.0
[00897963][11 00][05] v1.8.0.0 -> v1.8.0.0
[00898143][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00898238][11 01][00] v1.8.0.0 -> v2.0.0.33
[00898386][12 00][05] v1.10.0.0 -> v1.10.0.0
[00898538][12 01][05] v1.10.0.0 -> v1.10.0.0
[00898690][12 02][05] v1.10.0.0 -> v1.10.0.0
[00898875][12 03][05] v1.10.0.0 -> v1.10.0.0
[00898980][15 00][00] v1.1.2.0 -> v1.1.2.0
[00899132][17 00][00] v1.1.1.7 -> v1.1.1.7
[00899335][17 01][00] v1.0.2.7 -> v1.0.2.7
[00899455][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00899554][01 00][05] v1.23.4920 -> v1.23.4920
[00899654][01 01][05] v1.23.4920 -> v1.23.4920
[00900516][09 00][05] v3.0.0.10 -> v3.0.0.10
[00900616]Done.
[00900706]Firmware upgrading[3]...
[00904852][19 00] Firmware upgrade start...
[00935556][19 00] Firmware upgrade finish failed (step = 2, err = 0x08).
[00965658]Done.
[00965749]Version checking[4]...
[00965905][03 05][00] v34.2.0.9 -> v34.2.0.9
[00966046][03 06][05] v2.4.20.18 -> v2.4.20.18
[00966147][04 00][05] v1.44.0.0 -> v1.44.0.0
[00966328][11 00][05] v1.8.0.0 -> v1.8.0.0
[00966506][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[00966602][11 01][00] v1.8.0.0 -> v2.0.0.33
[00966766][12 00][05] v1.10.0.0 -> v1.10.0.0
[00966909][12 01][05] v1.10.0.0 -> v1.10.0.0
[00967061][12 02][05] v1.10.0.0 -> v1.10.0.0
[00967221][12 03][05] v1.10.0.0 -> v1.10.0.0
[00967317][15 00][00] v1.1.2.0 -> v1.1.2.0
[00967455][17 00][00] v1.1.1.7 -> v1.1.1.7
[00967665][17 01][00] v1.0.2.7 -> v1.0.2.7
[00967801][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[00967899][01 00][05] v1.23.4920 -> v1.23.4920
[00967994][01 01][05] v1.23.4920 -> v1.23.4920
[00968101][09 00][05] v3.0.0.10 -> v3.0.0.10
[00968203]Done.
[00968298]Firmware upgrading[4]...
[00972285][19 00] Firmware upgrade start...
[01002977][19 00] Firmware upgrade finish failed (step = 2, err = 0x08).
[01033075]Done.
[01033168]Version checking[5]...
[01033309][03 05][00] v34.2.0.9 -> v34.2.0.9
[01033451][03 06][05] v2.4.20.18 -> v2.4.20.18
[01033559][04 00][05] v1.44.0.0 -> v1.44.0.0
[01033730][11 00][05] v1.8.0.0 -> v1.8.0.0
[01033909][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[01034000][11 01][00] v1.8.0.0 -> v2.0.0.33
[01034164][12 00][05] v1.10.0.0 -> v1.10.0.0
[01034326][12 01][05] v1.10.0.0 -> v1.10.0.0
[01034484][12 02][05] v1.10.0.0 -> v1.10.0.0
[01034645][12 03][05] v1.10.0.0 -> v1.10.0.0
[01034747][15 00][00] v1.1.2.0 -> v1.1.2.0
[01034898][17 00][00] v1.1.1.7 -> v1.1.1.7
[01035073][17 01][00] v1.0.2.7 -> v1.0.2.7
[01035184][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[01035367][01 00][05] v1.23.4920 -> v1.23.4920
[01035465][01 01][05] v1.23.4920 -> v1.23.4920
[01035583][09 00][05] v3.0.0.10 -> v3.0.0.10
[01035677]Done.
[01035776]Firmware upgrading[5]...
[01039768][19 00] Firmware upgrade start...
[01070462][19 00] Firmware upgrade finish failed (step = 2, err = 0x08).
[01100557]Done.
[01100655]Version checking[6]...
[01100813][03 05][00] v34.2.0.9 -> v34.2.0.9
[01100960][03 06][05] v2.4.20.18 -> v2.4.20.18
[01101061][04 00][05] v1.44.0.0 -> v1.44.0.0
[01101255][11 00][05] v1.8.0.0 -> v1.8.0.0
[01101433][11 01][00] v1.8.0.0 -> v2.0.0.33, firmware v1.8.0.0 not support.
[01101532][11 01][00] v1.8.0.0 -> v2.0.0.33
[01101693][12 00][05] v1.10.0.0 -> v1.10.0.0
[01101862][12 01][05] v1.10.0.0 -> v1.10.0.0
[01102023][12 02][05] v1.10.0.0 -> v1.10.0.0
[01102173][12 03][05] v1.10.0.0 -> v1.10.0.0
[01102270][15 00][00] v1.1.2.0 -> v1.1.2.0
[01102423][17 00][00] v1.1.1.7 -> v1.1.1.7
[01102628][17 01][00] v1.0.2.7 -> v1.0.2.7
[01102749][19 00][00] v0.0.0.0 -> v1.0.8.96 need upgrade.
[01102850][01 00][05] v1.23.4920 -> v1.23.4920
[01102946][01 01][05] v1.23.4920 -> v1.23.4920
[01103067][09 00][05] v3.0.0.10 -> v3.0.0.10
[01103169]Packet upgrade failed at firmware upgrade.
