blunt___
Sean-bumble-bee Posted at 1-24 11:49
My concern would be, once the drone is above the range of the VPS i.e. more than 15ft above the floor of the "opening in the middle", and has insufficient GPS to establish the drone's position, the drone will switch to ATTI mode with NO position holding capability nor any automatic braking.
That would mean ALL horizontal control is your responsibility and YOUR'S ALONE, the drone will NOT assist you.
I have good clearance inside the opening, also, the drone will only go up/down the opening then pausing to take the 360 video. I have a staircase access which enables me to get the drone in case it gets stuck in a hover position.
DJI should give us an option to set a height limit once in ATTI mode instead of locking the height limit to 15 feet. My Mavic PRO Platinum is now useless indoor and I have to shop for a drone that would let me do whatever I want indoor. After all, I'm the pilot with the FAA license, I have insurance, and the owner completely understands the risks and he is okay with it.
Thank you for taking the time to respond. |
