Beta5K
Flight distance : 196880 ft
Lost Somewhere Posted at 1-30 11:01
Oh awesome, you're the guy I need!
I'm a mechanical nuclear pharmaceutical engineer so I make no claim to know aeronautics.
Like you said, the toroidal design is sort of like having 4 blades at each motor instead of 2. So if they have the same pitch and length and width, then the lift will be a lot more and it will spin slower but take more power. However, if I make the pitch a little less and the blade a little narrower, it might be closer to the original. If it doesn't work well, and I don't expect the first set to be perfect, then I can adjust any of the 3 parameters so that I can get back to the same RPM and lift. The idea is that it will be quieter, but I don't know if it will end up more or less efficient in the end, the losses are likely higher, and some noise reduction might just be from spinning slower. But they claim this design reduces noise, so I assume that should be at the same RPM, but who knows. It's fun to try.
Where'd you get the STL file for the drone? |
