No Original Thought
Flight distance : 1364209 ft
Tflo Posted at 7-12 10:10
The way I learned it is that cyclic control is related to changing the thrust vectors by applying force to the articulating arms via swash plates. This changes the angle of attack of each rotor as it enters different parts of the rotors cycle/rotation. This is a separate effect from rotor flapping. Cyclic control allows for directional control of the thrust generated by the lift disk. In a quad copter this is accomplished by increasing or decreasing the rotational speed of different rotors at the corners of the quad copter. In a single rotor system you have to change the angle of attack in different regions of the lift disk. Blade flapping is what makes an "Even" lift disk or equal thrust on all parts of the lift disk during forward flight. This is also one of the speed limiting factors of rotary wing aircraft. At some forward velocity the relative velocity of the retreating blade to the atmosphere is Zero, while the advancing rotor is moving very fast relative to the surrounding atmosphere, this would generate one sided thrust only and the helicopter would flip, lose control and crash. This of course occurs at lesser velocities as well, but the up-tilt of the advancing rotors generates large vortices at the rotor tip canceling out the lift effect for a large portion of the rotor thereby reducing lift/thrust on the advancing rotor; on the retreating rotor the rotor tip dips due to a decrease in lift/thrust as the rotational velocity of the rotor slows relative to the atmosphere. This creates a larger lift surface on the retreating rotor increasing the lift/thrust. This why single rotor systems always utilize highly flexible rotors.
Wow... I always knew there was a reason I stuck to fixed wing!
Fascinating things those rotorcraft, but the aerodynamics are just toooooo complicated. And to think that Da Vinci is credited with coming up with the idea when all he did really was stick an Archimedes screw on top of a bike! He had no idea of what it was going to really take to make one of those things fly and be controllable.
And as for auto-gyros - well, they are just witchcraft, surely.
