fosterdude
Hi Team,
I have a DJI Mini 2 which I have just replaced the gimbal housing after damage during a crash.
Repair was successful and camera moves well etc.
Before the repair, and after the crash, I also had error messages:
GPS signal low. aircraft unable to auto hover and takeoff restricted. Move to environment with adequate light. Unlocking takeoff restrictions not recommended(Code: 30239)
Vision sensor error. Contact DJI (Code: 180030)
Vision sensor error. Contact DJI (Code: 180031)
Downward vision sensor error. Contact DJI (Code: 180016)
GPS Signal weak. Hovering unstable. Fly with caution (Code: 30008)
These errors remain after the repair.
Furthermore, during repair, I noticed that the 'DJI Mini 2 Gimbal Camera PTZ Cable' had become dislodged from its 'socket' on the board.
From here, I assuming that this is most likely all pointing towards the cable being damaged and needing replacement.
May I please ask if this is likely to be the case with these error messages?
Thank you in advance
