Sean-bumble-bee
Flight distance : 15997 ft
Which log or logs are you asking about?
If the one's on the drone, you can't, they can only be over written by newer logs.
If on the screen device then the txt logs can, from memory, be deleted individually in the app. If you use a phone as a screen device then I'd connect it to a computer and use the computer to delete the txt AND DAT logs, can't help if you use a smart controller.
The above said why do you want to delete them?
If your are selling the drone then you need only worry about this if you are including the screen device with the drone.
I MOVE all my logs, txt & DAT, to computer. |
