How to connect the Osmo Action 3 via bluetooth to your Intercom
10071 29 2023-2-5
Rocktheasphalt
Switzerland
2023-2-5
johansenfoto
Flight distance : 1180089 ft
Norway
This was a good experiment, and the sound is really good
Didn't understand everything, but got the important points.
2023-2-5
Rocktheasphalt
Switzerland
I noticed some issues with the automated translation, i'll try to fix it...
2023-2-5
johansenfoto
Norway
Rocktheasphalt Posted at 2-5 14:22
It only translate to german for me, maybe I do something wrong when clicking
But since Norwegian is not way too far away from German, I do catch up some of things you said.
Edit: now I found out, and got it to translate to Norwegian
2023-2-5
Rocktheasphalt
Switzerland
Nice, now you can understand the story at the end
2023-2-5
Fishycomics
was just viewing   excellent job   $30.00 product here at US Amazon.
2023-2-5
Montfrooij
Flight distance : 2845026 ft
That looks (and sounds) good!
2023-2-5
bonobox
Austria
i didnt get the brand of the usb microphone/headphone which are in the helment.
Does this work with any intercom system such as cardo/sena ?
2023-2-6
Rocktheasphalt
Switzerland
bonobox Posted at 2-6 04:47
I´m using the SC1 Advanced from Senna, connected in multimedia mode. The bluetooth adapter connects  to all headsets using Bluetooth 5.0. Check the link in the video description.
2023-2-6
bonobox
Austria
Rocktheasphalt Posted at 2-6 05:11
I´m using the SC1 Advanced from Senna, connected in multimedia mode. The bluetooth adapter connects  to all headsets using Bluetooth 4.1. Check the link in the video description.
and could you pair two device so that you can keep using the intercomm ?
2023-2-6
Rocktheasphalt
Switzerland
bonobox Posted at 2-6 06:54
I could pair two device but was not able to use both at the same time... I only could switch with the button on the Adapter from audio to cam to audio to intercom. The adapter is able to connect to two device maybe this is the way to go...
2023-2-6
m326
This all sounds interesting and the audio was certainly good quality.
In fine weather it's all well and good having cables or BT devices sticking out... but is anyone making anything to make them a bit more weather resistant?
2023-2-6
johansenfoto
Norway
I have a Cardio bluetooth system in my helmet that I rearly use because my atv is too loud for me to hear the others lol
But maybe I need to check if I could pair it with a bluetooth device like this, but not sure if I bother to even try.
Need to see when driving season starts in May.
2023-2-7
Rocktheasphalt
Switzerland
johansenfoto Posted at 2-7 01:21
It would certainly be interesting to see if it also works with the Cardo, unfortunately I only have Senna headsets here...
2023-2-7
Kamen666
Flight distance : 339035 ft
Bulgaria
I think the result is more than satisfactory.
2023-2-7
johansenfoto
Norway
Rocktheasphalt Posted at 2-7 02:21
Will see in spring if I will be testing it
2023-2-7
Rocktheasphalt
Switzerland
Testing battery drain...
2023-2-9
johansenfoto
Norway
Impressive.
I wonder if it uses front lens as part of cooling?
2023-2-9
Rocktheasphalt
Switzerland
It was the hottest part of the Cam, actually a good strategy...
2023-2-9
skysailor64
johansenfoto Posted at 2-9 12:31
Impressive.
I believe I have read DJI material/statements that affirm the lens and lens protector are part of the heat sink technology on the OA3.  I seem to also recall they made the statement that the rubber ring on the lens protector is also part of that technology.
2023-2-9
johansenfoto
Norway
Rocktheasphalt Posted at 2-9 13:48
Yes that's why I was thinking it was part of it
2023-2-10
johansenfoto
Norway
skysailor64 Posted at 2-9 14:41
Ah nice, that is really good since it will be a good cooler
2023-2-10
lutzmix
the silicone rubber ring is an isolator
I dont use it
2023-2-10
johansenfoto
Norway
lutzmix Posted at 2-10 08:23
I dont use it
Yeah probably best to take it off for best cooling
2023-2-10
Rocktheasphalt
This time i compared the Avantree C81 adapter with the BOYA BY-K4.
Can't wait for your feedback.
As always, the video is in German, but there are subtitles.
2023-3-16
johansenfoto
Norway
Rocktheasphalt Posted at 3-16 10:52
This really a good test, and clearly show how the sound could be better.
2023-3-17
Rocktheasphalt
johansenfoto Posted at 3-17 02:31
I've tested other adapters in the meantime and I have to say, the Boya BY-K4 adapter is the least suitable for motovlogging...
2023-3-17
johansenfoto
Norway
Rocktheasphalt Posted at 3-17 07:43
Ah okay. Can't wait for your next testing that gave best result
2023-3-17
lutzmix
hallo Andreas
can you test this
bluetooth adapter connecting your earbuds
you can try if it works with earbuds too.  Should work with the Insta 360
2023-3-23
Rocktheasphalt
Switzerland
lutzmix Posted at 3-23 23:44
hallo Andreas
can you test this
I was able to connect my Galaxy Buds to the Avantree C81 adapter with no problems, however the audio sounds similar to the Airpods in his video. But that is due to the Bluetooth protocol used for the connection. If you have the option of connecting a wired microphone, the sound will be recorded in a higher quality than with this type of wireless transmission. On the motorcycle, however, it's a viable option because it cuts off exactly the frequencies that would otherwise be annoying, and you don't have a cable. The limitations of the Bluetooth protocol are also the reason why the DJI Wireless Mic has both a transmitter and a receiver.
2023-3-24
