osmonauta
Hungary
You know you could simplify this process a little by using a 4K “template” clip.
1. Take a 4K video of anything. Doesn’t matter what it is. This will serve as your “template” clip.
2. Import this into iMovie, cut it down to just 1 second (or even to just a single frame), then export it as a 4K video.
3. Now you no longer have to film in 4K first, just in 1080. Every time you want to edit, just bring this 4K “template” into iMovie as the very first clip in the timeline. (iMovie interprets the project resolution based on the first clip on the timeline.)
4. Then bring in your 1080 clips into the timeline and delete the “template” (which was 4K) from the timeline. The project is already interpreted as 4K so you can edit the way you like and output it as 4K.
This way you don’t need to shoot the first video as 4K because you can just reuse your “template” as the first one. |
