soakingwords
Flight distance : 192966 ft
Hi, yep exact same issue, on same hardware and OS.
Click on 'Calibrate' and get a 'Cannot recognise screen size' error message, and asked to enter screen size.
I wasn't able to put anything but numbers into the 'screen size' dialog box (no spaces or 'x' or other letters - I assumed it was after pixel dimensions?). After inputting: 51202880 (? which would be 5120x2880 ?) I had the same issue of the calibration screen starting up (and after running through the 'how to instructions'), I could get the drone to the correct distance from the screen for calibration (blue corner edge lines), the first calibration box appears and ticks off and then as soon as you rotate the drone to face the next calibration box I would always get a 'movement error'.
- no amount of uninstalling and reinstalling software, turning off and on drone or simply restarting the software would get any different results.
Please correct this dji - I don't think saying 'use a windows computer' is a very professional or satisfactory response - especially as the software is available for macOS.
(just fyi: I didn't get this sort of issue on an iMac with the Mavic 2 Assistant using macOS Monterey).
Thank you. |
