GL300E and Mapbox bug
123
6921 94 2023-2-11
Michael Starley
Flight distance : 2812 ft
DJI Tony Posted at 2023-11-21 01:34
Hi, ItzFilyO. We suggest trying to download the firmware from the official website first. https://www.dji.com/downloads/products/phantom-4-pro I that does not work, I will send you a message.
1.  Import the file “update.zip” into the microSD card.
Note: If the upgrade fails via an SD card, please copy the update.zip file to the internal memory of the remote controller and try to upgrade again.
Hello DJI Tony!
I am also having this issue with the  MapBox Bug on the GL300E controller.
I have downloaded and installed the latest firmware from the dji web site.
Still no chicken dinner.
Can you send me the usb flash drive patch file?
Thank You!
1-3 10:32
DJI Tony
Michael Starley Posted at 1-3 10:32
Hello DJI Tony!
Hi, Michael.  If the suggested method does not work, please kindly check your forum inbox as I sent you a message. I appreciate your patience.
1-5 23:51
fans0d2c64d4
Flight distance : 52651 ft
Argentina
can someone send me the link for the solution?
1-7 14:58
DJI Tony
fans0d2c64d4 Posted at 1-7 14:58
Hello there. I sent you a message, please kindly check your forum inbox. Keep us posted if the issue persists. Have a great day ahead.
1-7 21:41
TimSauter
Flight distance : 2024 ft
Hello DJI Tony,
I also have an Phantom 4 Pro and a GL300E. Unfurtunately my GL300E also shows a black mapbox. I already tried the firmware verison 1.4.3.0 from the DJI website. I could install that firmware, but the mapbox stayed black. Can you send me the link like the others as well?
Kind Regards,
Tim
1-25 13:05
Michael Starley
DJI Tony Posted at 1-5 23:51
Cannot thank enough!
1-30 16:28
DJI Tony
TimSauter Posted at 1-25 13:05
Hello DJI Tony,
Hi. Please kindly check your inbox. I have also sent you a message. Keep us updated if you encounter any other issues. Have a great day ahead.
1-30 20:20
fans75d7f38e
Flight distance : 9665108 ft
I would like to receive the firmware/APK version to solve the map problem. I tried but all the download links have expired and the firmware V01.04.03.00 published on the official DJI page does not solve the problem
2-21 04:34
Evgeny Klimov
Russia
Hello!  Send me a link to the firmware for the GL300E remote control. Upload the file to perpetual file storage.  Why are you uploading a file to temporary file storage? Make a page with the file on this site or download the update to the official website dji.com
2-24 01:19
DJI Tony
Evgeny Klimov Posted at 2-24 01:19
Hi there. I replied to your message. Please kindly check your messages. Have a great day ahead.
2-24 01:34
DJI Tony
fans75d7f38e Posted at 2-21 04:34
We apologize for the inconvenience. You may download the firmware of the remote controller to the microSD card, and then update the firmware manually.
Note: If the upgrade fails via microSD card, please copy the update.zip file to the internal memory of the remote controller and try to upgrade again.
2.  Power off the remote controller and insert the microSD card.
3.  Power on the remote controller and tap “Install”.
Please keep me posted. Have a great day.
2-24 01:51
fansa74b3192
Indonesia
DJI Tony Posted at 2-24 01:51
We apologize for the inconvenience. You may download the firmware of the remote controller [view_image] to the microSD card, and then update the firmware manually.
I have the same issue with the mapbox not working. Can i get the link as well?
Thanks
2-25 05:11
DJI Tony
fansa74b3192 Posted at 2-25 05:11
Thanks
Hi there. Please use this link https://pan-sec.djicorp.com/s/RYG8R68Z3TbX8bw and follow the procedures above. Please keep us posted. Have a great day.
2-25 23:58
fansa74b3192
Indonesia
DJI Tony Posted at 2-25 23:58
The map works now as it should. Thanks
2-27 00:48
DJI Tony
fansa74b3192 Posted at 2-27 00:48
Perfect. I'm glad to know you got it working. Please don't hesitate to reach us if you need further help. Have a nice day ahead.
2-27 02:35
123
