DJI Wanda
Hello, there. Sorry for the inconvenience. Would you please check the information below and tell us your feedback?
1. After the DJI Pro SSD is connected to the computer, check whether the rear LED lights up.
* If the rear LED lights up, it indicates that DJI Pro SSD is powered on.
2. Check whether a docking station is used when connecting DJI Pro SSD to the computer.
* When a docking station is used, check whether it can supply power; if the docking station does not provide an independent power supply, try to remove the docking station and directly connect the DJI Pro SSD to the computer.
3. Connect another USB-C to USB-C or USB-C to USB-A cable to the computer.
4. Check whether another storage device connected to the computer port can be recognized normally.
5. If there are no backup requirements for the photos/videos, please connect DJI Pro SSD to DJI Ronin 4D to check whether it can be recognized. If it can be recognized, format the DJI Pro SSD using DJI Ronin 4D.
6. If possible, use another computer to test.
