djiuser_SAZShCThOQeM
Flight distance : 274636 ft
Trinidad and Tobago
WernerD Posted at 2-12 21:43
Flying with headtracking might be a workaround.
On the request as such, yes, if I want to reduce the altitude fast it does not necessarily mean I want to film the ground. Maybe an exponential setting would do the trick - you look 20° downwards but the drone flies 80° downwards?The ultimate answer will probably be, do not fly with the Motion Controller but the FPV Controller.
I’m talking about flying with the fpv controller in normal or sports mode and get that gimbal movement like when you’re using the motion controller to go higher or lower. It can be achieved by flying forward and upwards then turning the gimbal dial to adjust but it’s kind of hard to use all the knobs especially if I need to turn as well. Might be an interesting feature to add. Currently learning manual mode to give that fpv feel to videos. |
