DJI Mavic 3E - camera center
1942 13 2023-2-14
Simptonym
Flight distance : 981598 ft
Slovakia
Hello everyone, I would like to use M3E as a GNSS rover for marking GCPs and for that I need to know how much milimetres is from sensor of camera to front element of lens. Does anyone know this?
(based on inspiration from this with P4RTK https://www.pix-pro.com/blog/post/gnss-rover-drone)
2023-2-14
LV_Forestry
Flight distance : 4726654 ft
Latvia
I have already partially answered a similar question.  This might interest you:
https://forum.dji.com/thread-284029-1-1.html
Afterwards, you have to remain lucid, with this kind of method it is a little utopian to want precision levels of the order of a millimeter.  Measure the distance between the GCP and the camera, you should get pretty close.
What do you use?  DRTK2, PPK or NTRIP?
2023-2-14
Simptonym
Slovakia
I am definitely not looking at precision lower than 1cm. I will use RTK (NTRIP) and if not available PPK.
2023-2-15
LV_Forestry
Latvia
Simptonym Posted at 2-15 14:19
I am not a native English user.  If you are looking for precision below the centimeter:   You can forget about measuring GCPs with the M3E, and start looking into investing in a GNSS rover receiver and its base station.
Forget the NTRIP too, you have little chance of achieving precision below one centimeter.  With the PPK it is already more reasonable.  Even if hoping to reach this level of precision with photogrammetry is a bit illusory, it is not impossible.
Otherwise: The accuracy of NTRIP and PPK will depend on the distance from the base station.  You can once again use your own base station by placing it on a cadastral mark measured beforehand.  Or by connecting to an NTRIP network and doing an average for a while.  It's not PPP, which is the ultimate technique, but it does the job.
Good luck.
2023-2-15
LV_Forestry
Latvia
You can send me the dimensions of the position of the M3E camera in relation to the landing gear. I can draw you a platform to print in 3D. Similar to the one I have for my P4R which I use to measure GCPs.
2023-2-15
Johnnokomis
Flight distance : 12749816 ft
LV_Forestry Posted at 2-15 22:22
[view_image]
Does this gives you every measurement you'd need to draw up this device? I'm very interested in this concept of the M3E to shoot checkshots with.
I'm not sure if it'd help at all but I also have free 3D model of the M3E you can download from Sketchfab. It has no scale reference but everything is proportional in regards to the size.
Mavic 3 Enterprise 3D Model
2023-2-28
LV_Forestry
Latvia
Yes it should be enough.  I will draw it tomorrow.
2023-2-28
Simptonym
Slovakia
LV_Forestry Posted at 2-28 12:56
Also, regular Mavic 3 model is available here: https://www.thingiverse.com/thing:5155706. I guess they are the same.
2023-2-28
LV_Forestry
Latvia
Johnnokomis Posted at 2-28 12:32
You will find the 3D printer file. As well as a PDF with a 1: 1 drawing. You can print it or put it on a ladder on a screen to test before wasting plastic if the dimensions are not good. I took up the dimensions you show in the photos. The Symptonym' STL file is not at the scale, Thanks anyway.
M3E_GCP.rar (65.01 KB, Down times: 9)
2023-3-1
Johnnokomis
LV_Forestry Posted at 3-1 01:28
Thank you for taking the time to make this. I would love to try it out but it's too big to be printed on a normal sized bed. I'll send it off to be printed but my question is, how will the pitch of the drone be affected by this? The RTK module sits at a decent pitch when the M3E is on a level surface. Does the IMU account for this pitch or how accurate is the IMU anyways?
2023-3-1
LV_Forestry
Latvia
Johnnokomis Posted at 3-1 09:41
Thank you for taking the time to make this. I would love to try it out but it's too big to be printed on a normal sized bed. I'll send it off to be printed but my question is, how will the pitch of the drone be affected by this? The RTK module sits at a decent pitch when the M3E is on a level surface. Does the IMU account for this pitch or how accurate is the IMU anyways? [view_image]
If you give me the dimensions of your printer I can split the part.
Theoretically the lever arm between the center of the phase of the receiver and the center of the camera is calculated directly in the drone, according with IMU and compass data. It will be necessary to measure the distance between the GCP and the lens of the camera. I did this way for my P4M, I rounded up to 5cm. It is certainly not the exact value but comparing with a Trimble receiver the results are extremely close.
2023-3-1
LV_Forestry
Latvia
I split it in 4, you can put it together by putting toothpicks in the grooves and hold everything together with hot glue or PLA/ABS that you just melt on top.
M3E_GCP_Split.rar (81.57 KB, Down times: 2)
2023-3-1
DRONE-flies-YOU!
Flight distance : 1450594 ft
LV_Forestry Posted at 3-1 10:06
Which Mavic 3 Enterprise drone do you have?
Curious if you could test something with the thermal.
2023-3-1
LV_Forestry
Latvia
DRONE-flies-YOU! Posted at 3-1 23:55
Mavic 3 is a standard platform shared by all variants of the range. The dimensions of the arms are theoretically the same on all. What can change is the center of the camera. But at a glance between 3E, 3T and 3M, there is no significant difference. At least always included in the accuracy of the receiver.
You can print the PDF contained in the RAR archive, then see if the dimensions are consistent with that of your drone.
If there is need to modify the 3D file, please send the dimensions.
2023-3-2
