Flyhigh7887
Sweden
Hi Lyle,
As stated by a few here, the VPS is only "active" until around 3 meters/ 10 feet. It is not meant for position stabilization higher than that. I fly mine around my apartment all of the time, but to be honest I do it when no one else is home. I try to use these times as practice flying for tight situations.
The VPS is handy in some situations, and works as advertised. Mostly I would just try to practice as much "manual" flying as possible for indoors, without the reliance on VPS or anything else. You will pick it up and be able to get some decent shots once you come to terms with your surroundings & the P3 itself.
p.s.- if you are going to be flying inside mainly, I imagine that prop guards will be your new best buddy...
Good luck & enjoy it!
edit: do turn off P mode when flying indoors, if by chance you snatch a gps signal it can go a bit wonky at times...
