fansec97bfb6
Flight distance : 710125 ft
DJI Gamora Posted at 2-19 01:16
Hi, Danny99. Thank you for reaching out. Have you tried flying your drone with this RC? If yes, did you receive any RC error from the goggles? Can you do Combination Stick Command and take off in N mode, then switch to M mode in the mid-flight? Please try the following steps below:
• Calibrate the RC - After linking the DJI FPV Remote Controller 2 to the DJI FPV Goggles V2, go to "Settings" -> "Remote Controller" -> "RC Calibration", and you can then run calibration for the Remote Controller 2.
Hello, i have the exact same problem, i am using the Samsung S21 Ultra model and the fpv controller is update to the last version and also the dji virtual flight app is the latest one loaded on the website.
Any possibikity to adjust the travel of the joystick. By using the drone everything is working fine, with the virtual flight i experience this problem and i cant throttle to the minimum value, this happens if i connect by cable the controller to the phone, instead if i connect the controller to the googles integra and the googles by cable to the phone everything is ok |
