Johnnokomis
Flight distance : 13349895 ft
kyr Posted at 3-4 13:32
Would it be possible to do this with the Phantom 4RTK as well? We bought the M300 RTK and D-RTK2, but it seems that we can’t use the D-RTK2 station as a rover. To seize this opportunity, we need to buy the Phantom 4RTK RC, which is strange. It would be great to install the APK on a second-hand phone to use all the functionality of the D-RTK2 that DJI declares.
Maybe it's different for the P4RTK, but with the M3E and M300/350's just the RC won't be enough to connect to the D-RTK2. The drone connects to the base and acts as a middle man with the RC. Even if it was as simple as installing the APK, the D-RTK2 as a rover will give very poor results. Using it as a base on a known coordinate has issues already. So using it as a rover will be far worse. Best bet is to return your D-RTK2 if you still can and get something respectable. An Emlid RS2, RS2+ or RS3 will all be cheaper, provide survey grade results and can be a base and rover if you have an NTRIP provider in your area. |
