JJB*
Flight distance : 12225059 ft
Hi,
Had a look at your log too.
Last records your Mini3Pro was flying backward with 100% stick aft,
speed increasing from zero to 10.3 m/s
Baro height indication height of 3 meter, last to record 2.9 meter.
VPS height not measuring, normal flying fast over water with drone pitch up off 23 degrees UP.
As the log stops, not possible to know why it got wet.
But loosing connection means that a drone will rapidly stop the motion by forcely braking.
Doing this is it is 'normal' to loose some height.
IMO ; Flying low + loosing height = wet.
Batt temp at start : 20 degrees C, end of flight 25, so drone internal temp not too cold, batt cell values all normal.
5x warning "High altitude. Fly with caution" in the log, this when flying at low altitude. uh?
cheers
JJB [ Chart by FRAP ; the 'best' software for flightlog analysis ] |
