BladeZ
Flight distance : 1139852 ft
Tonyvdb Posted at 3-2 09:04
Ok, so an interesting development. I tried two different cards from other manufactures that I had around, they both do the same thing as the other cards. I then downloaded the DJI assistant2 to try doing a refresh on the drones firmware and hooking the drone up to the USBc port on the drone to my computer and low and behold that is not working either. DJI assistant does nothing (Yes the drone is powered on)
Now I am confused, what is going on?
Are you using USB C to USB C or USB A to USB C? I had this same problem, but with my controller, using USB C to USB C and when I switched to USB A to USB C (USB C being the Drone), it worked fine. After I refreshed the firmware on the controller it would work fine using the USB C to USB C.
Just something else to try.  |
