Oregon_LiDAR
DJI Natalia Posted at 3-6 20:08
Hi, there. Sorry for the belated reply.
May we know if your problem is resolved now? If not, please check the following suggestions and see if your problem can be resolved:
For your problem, we recommend that you upgrade the current remote control, aircraft, and L1 firmware versions to the latest firmware version. If the same error still appears after upgrading to the latest version, please re-plug the gimbal cable and reinstall the L1 gimbal camera. If possible, it is recommended to replace other loads or install L1 to other M300s for cross-testing.
Hi,
Thank you for the response. I’m actually also unable to update the firmware like I said- I’ve tried several times to update and each time the update ‘failed’.
