djiuser_zW2WCKdG79uP
Flight distance : 7947890 ft
DJI Tony Posted at 3-1 19:49
Hi, Thom. Thanks for reaching out. To answer your question, you may use the DJI RC for both drones and not void your DJI Care Refresh plan, especially the Flyaway Coverage. Please note that binding the aircraft with the remote controller records the linking relationship between the drone and the remote controller. If the aircraft is lost due to a flyaway incident, you can request to use DJI Care Flyaway Coverage. Not binding the aircraft with the remote controller will result in being unable to use DJI Care Flyaway Coverage. If you want to use the DJI RC on your flight, you must bind it to the aircraft first. Ultimately, you must bind the remote controller you need to use in a flight (whether the RC-N1 or the DJI RC). Here's how you can change the bound remote controller:
1. When the "Change Bound RC" option appears on the FPV screen, select it.
2. On the DJI Fly app, go to Profile>Device Management> Value-Added service>Unbind RC. You may unbind the RC first, then connect the remote controller you want to use (DJI RC), and the "Bind New RC" option will be available.
Thank you for your reply! Before I do this I want to be sure of myself - from the RC-n1, which is currently the bound controller, I select the "Unbind Device" option (in red) on the "Value-added Service" panel of the Device Management section? When I select that option I receive a warning: "DJI Care Refresh Flyaway Coverage is still valid for your aircraft. Unbinding your devices will result in being unable to use this coverage" - which sounds like something I do not want to do! I would like to be able to use the Air 2S original RC-n1 and the new DJI RC interchangeably, as needed for the shoot, without disrupting my Care Refresh plan for either the Air 2S or the Mini 3 Pro (which supplied my DJI RC). And, if I do "unbind device" and then bind the DJI RC to the Air 2S will I need to go through this unbind-bind procedure each time I wish to swap remote controllers? Thank you for your patience with all my questions!
regards,
thom
