DJI Gamora
Hi, djiuser_1XczAwe3i5QT. Thank you for reaching out. The direction of the boomerang can be set. The aircraft takes the initial location at the starting point, flies around the target on an elliptical trajectory, and flies back to the starting point to take pictures. When using it, make sure there is enough space around the aircraft (30m radius around and more than 10m space above). The original video size is up to 4k 30 frames. |
