Jake. A
Flight distance : 1205715 ft
DAFlys Posted at 3-13 07:04
Right but when you export it and play it back locally is it in the correct format, For example if I start a project thats normal 4k resolution and add a vertical clip the editor will add the bars, if I want it to be portrait I start a project in that resolution and then import my clips. Then the export plays back just like the original, then it depends where you host it to how it places, for example YouTube had a vertical player.
ok, that helps a little, but I'm still not fully understanding for some reason.
I imported my vertical clips into the editor (Davinchi) and it automatically uses black colored bars. I want these to be white to look better on skypixel. |
