DJI Tony
In addition to that, here are some scenarios where QuickShots will not work that should be taken note of:
1. If there is no microSD card, QuickShots cannot be used.
2. If the aircraft has entered ATTI mode or another mode, the QuickShots function cannot be used. (Only in N mode).
3. Quickshots cannot be used when the aircraft takes off at an elevation below 2 m.
4. If a subject is not selected or Start has not been tapped, QuickShots cannot be triggered.
5. If the light is insufficient or there are obstacles in the environment, there might be a calculation error due to visual factors of the target distance. As such, the DJI Fly app will not be able to stitch together QuickShots videos.
6. If the device is incompatible, QuickShots cannot be used.
We recommend you consider these things when using the QuickShots function. Have a nice day! |
