ValleyForge
Flight distance : 24754 ft
CrystalSky is a great screen but is almost a legacy product now as it runs on Android5. But you can get your FPV video feed to the CrystalSky at around 50fps and it's a robust feed and more than good enough for flying (not bat-... crazy stuff though).
CrystalSky running Android 5.1.1, FW 3.0.2.0
Goggles FW 01.06.00.00
Download the FPV-DVCA APK for Android (must be the APK) and load it onto the root directory of a microSD card. Load the card into the CS and go to Explorer/SD Card and open the FPV-DVCA install.
You'll need a USBC to USB-A lead to join the goggle to the CS and with DVCA running via the Applications screen on the CS you should have a video feed. I found the "Direct-Bufffered" setting best.
And, no the microUSB and USBC ports on the CS won't work. DVCA only recognises the USB-A slot.
Bon chance!
