DJI Tony
RayBones Posted at 3-23 12:08
Hi, I’m having exactly the same problem. Just was curious about manual settings and now I can’t get the drone connected. Removing memory card didn’t help. Pressing power button on aircraft for 4 seconds doesn’t start pairing procedure. Any help would be appreciated.
Thanks,
Hi, Ray. We're sorry you're experiencing the same issue. Here are some recommended troubleshooting steps you may perform:
1. Confirm that the remote controller and the aircraft have been powered on.
2. If there is an SD inserted, please remove the microSD card from the aircraft and restart it.
3. Switch the linking method between “Linking with the app,” and “Linking with combination buttons.”
4. If it is invalid, check whether the remote controller has been updated to the latest version. Connect the remote controller to the app. After the connection is successful, check whether there is a prompt to update the firmware. If yes, update the firmware to the latest version and try linking again.
5. If the linking still fails, please check whether the aircraft firmware has been updated to the latest version. Connect DJI Assistant 2 (Consumer Drones Series) and update to the latest version and try linking.
If the issue remains, please record the linking process and share it with us. Thank you for your cooperation and understanding. |
