tfernandes
Flight distance : 17100 ft
DJI Paladin Posted at 3-14 22:32
Hi there. Thank you for bringing this inquiry to us. When using Manual mode, it is recommended to tighten the F2 screw on the rear of the throttle stick so that the stick does not return to the center and adjust the F1 screw to make sure that stick resistance is suitable. However, if you want to switch to normal or sports mode, the stick will not recenter so please be more careful when flying in normal or sports mode with the adjusted stick. If you want to fly in Sports or Normal mode, it is better to return the sticks to their normal position after landing. Please don't hesitate to reach us if you have other inquiries. Thank you.
Thanks a lot. But I would like to know when I need to fly the quad in normal and sport do I need to again loosen or tighten the f2 screws as I did earlier.
Also do I get the tool to tighten the screws with the quad as I didn't find any screw driver in the package.
