djiuser_xp22w5ZmmFMg
Flight distance : 1846860 ft
DJI replaced my smart controller under warranty because the plastic body had cracked in two places at the corners of the screen.
However, now it won't link correctly with my mavic 2 pro. It links fine, then cuts out, I was doing a test flight and it brought up a message saying weak transmission signal, then cut out totally causing a RTH, the m2p was only about 100m away at that point with antennas orientated correctly, there was almost no interferance from external signals.
I've tried a factory reset.
I've tried refreshing the firmware (which is the latest version), both over wifi and using assistant 2, but that cancels part way through install.
I've tried formatting the SD card, and using none.
I've tried with the wifi on and off.
It does it in Go4 and when just powered on in the first menu (yellow lights start flashing).
Nothing seems to help.This is costing me work!
Any ideas?
