DJI Wanda
Hello, there. Sorry for the late response. We got the response from our engineers.
Here is the specifications of the standard charger:
Model: QC24.CN
Input: 100~240V~50/60Hz 0.8AMax
Output: 3.6~8V⎓3.0A/12V⎓2.0A
When charging with a standard charger, it takes about 2 hours to fully charge a DJI Smart Controller, and the maximum battery life is about 2.5 hours.
We still recommend you use the standard charger and data cable.
1)If the original charger and data cable are used, please connect the charger and data cable again. If the issue persists, please send back the products for repair( the charger, data cable and the DJI Smart Controller/DJI RC Pro).
2) If a third-party charger is used, the charger needs to support QC2.0 or higher charging protocol, or the prompt will be shown. It is recommended that the original charger and data cable be used.
3) If a third-party charging cable is used and the prompt is shown, the cable quality is poor. It is recommended that the original charger and data cable be used.
kindly noted that we do not recommend connecting to PC for charging because we can not guarantee the power output of the PC. |
