Tillikum
Flight distance : 523842 ft
Hi, New to gimbals and have recently purchased Osmo Mobile 6 amd RS3 Mini. Having a few issues.
1/ using pan follow, both gimbals are a bit erratic in pan movements. Seems like they are slow to respond and then do a quick pan (as in catching up). Ideally I’d like to see a continuous smooth pan. (Fuji X-T4/18-55, iPhone 13 Pro)
2/ walking forward I can see subtle swaying from side to side. This is more exaggerated with the mini especially with a heavier lens. (sam gear as above)
3/ RS3 Mini; with a heavier lens/fuji x-t4/55-200, when I squeeze the trigger to lock gimbal orientation, the gimbal slowly turns to the right as far as it can go.
Note: gimbals balanced and calibrated prior to use
Any advice on this would be appreciated. |
