Sean-bumble-bee
Flight distance : 15997 ft
Palliativo Posted at 3-19 01:35
The reason is very simple, Sean-bumble-bee. I don't have a micro sd card reader, I am on a tiny island in the Philippines and no way to buy it for the next few weeks.
That's a good enough reason but be careful of the drone overheating, I suggest you direct the output of a fan over and under the drone, to help cool the drone. I imagine the Philippines are quite warm, which would add to the likelyhood of over heating.
That said, I just noticed the comment about the strap. I would definitely remove the strap - so that the motors can twitch, and especially if you are using a tray type drone holder and strap as I would worry about the strap etc. adding to the ventilation restrictions. But, to be honest, I doubt undoing the strap and opening out the arms would take more than 15 seconds so it isn't a great hardship in the first place.
Ditto leaving the gimbal cover in place, that is likely to be another restriction to the ventilation.
In the second place, I doubt you would have to do it that many times in the next few weeks unless you are, for each flight, one by one, going to pack everything away, get to a computer and download the limagery. |
