DJI Gamora
Hi, umaruwa. Thank you for reaching out. Please see the details below
1. It is not recommended to fly the aircraft close to the water (within 2 m from the surface). When flying above the water, the vision positioning function maybe not function well and only the GPS and barometer are used for positioning. The aircraft may even drop into the water. The main factors that affect the drones’ GPS signals are environmental barriers, signal interference, and GPS hardware malfunction. Multi-path effect: That is to say, a large area of the reflective board, a large area of water, etc. It will affect the RC signal by the surface and get weaker.
2. Yes, it will be affected by environmental factors including the density of the air. Electric ionization layer: You can't see it intuitively. But when the time and temperature and the weather, the density of the air is changing dynamically. Generally speaking, less affectable factors will be better than versa.
Hope this provides the information that you need. Thank you for your support.
