DJI Wanda
LudvikRa-Bakk Posted at 7-22 14:03
I check on the sd card. I turned off the "cache" video that save video in the app because i did some research and somone said it fixed it when the cache videoes vere turned off but it only helped a bit. I dont have a pc now so i cant watch or transfer the videoes to the phone so i cant send you the video. But i can explain more. So it was snow outside on the trees and i wanted to film it because it was beautiful from the top and i flyed near the bushes and when i turned the drone around like around a tree an when i was flying back it lagged or misses picels or idk how to explain it but it was blury and laggy when i turned and good when i was just flying without turning the drone.
So we have to confirm whether the original video in the SD card is also laggy and blurry as you said in the image transmission view. Based on your description, we can only assume that when you turned the drone, the transmission might be interfered with. Would you please confirm whether the same issue will occur no matter which place you go? |
