DJI Tony
reesolar Posted at 3-19 19:40
You have solved the problem, thank you. Is it possible to have the video mode the default mode when I start up the drone? Thanks for your time.
You are most welcome. In addition to DJI Wanda's suggestions, the default mode will be the last mode you used before turning the device off. For example, the last setting you used was Video mode, when you turn the drone on, it will directly switch or default to Video mode. So we suggest you keep Video mode before turning the drone off. In case you forget, you can just always switch back when you turn the drone on. |
