Pilot 2 MBTiles import
LV_Forestry
Flight distance : 4726654 ft
Latvia
Tutorial to add custom maps to DJI Pilot 2. In this example I use Global Mapper to generate the Tile, it's not the cheapest, there are probably others.
As usual, I'm not affiliated with the manufacturers of the software I'm taking as an example, just a satisfied user.
A/ Displays on Global Mapper the necessary layers.
In this example what interests me is to see the riverbed that appeared on the LiDAR data after removing the vegetation.
B/ Once the visual on the screen suits you, right click on the layer, layer, export.
C/ Select "MapBox MBTiles Tileset"
D/ Adjust the zoom level.
For the number of zoom level I put the same thing as the max zoom. This way I find it more practical to use. If you only put a few levels, the map will disappear when navigating the RC depending on the zoom level.
E/ Export to SD card or directly to RC memory via USB cable.
F/On the RC, Open Pilot2 Settings, then "Map Settings"
G/ Choose "Custom Layer"
H/ Choose "Import"
I/ Choose the MBTile file in the folder where it was saved.
You can see what it looks like by tapping on the map icon.
J/ Make the layer visible in the trajectory planning interface.
K/ Enjoy
3-20 09:03
djiuser_5InBLucOeljy
Flight distance : 1265121 ft
Portugal
Hi,
I already tested with raster files, and it works just fine.
Thank you so much for your help.
3-21 04:59
Axelz
Flight distance : 1789915 ft
I wondered if anyone had had success with software other than the Globalmapper as shown above to generate these tilesets?  I've attempted to generate mbtiles for two areas I've mapped I was keen to have on the DJI Pilot 2 application rather than the older inbuilt map sources, however it just crashes the app when clicking the eye icon to show the layer once in the area.  Tried with MapTiler (free version) as well as Agisoft Metashape with various mbtile export file format combinations and sizes, they show after importing correctly in the application after importing. Tried with webp, jpg and png formats also. Latest DJI Pilot application and firmware on the mavic 3 enterprise and RC Pro Enterprise controller.
5-15 13:22
Johnnokomis
Flight distance : 10973750 ft
Axelz Posted at 5-15 13:22
I've spent the last  4 weeks mapping this gigantic area with Metashape. Exporting MBTiles using these settings seem to import perfectly onto the RC. I use my latest MBTiles to know what areas need mapping next.
5-15 17:31
Axelz
Thanks I've tried with similar settings from metashape (PNG and smaller total size as far smaller area) and it still crashes unfortunately, though does show correctly still in the preview with a black and white map overlay around it as before, very odd. Using latest DJI Pilot 2 6.1.1.1.  I'll contact DJI support to see if they can try the same mbtiles and see if they can recreate.
5-16 11:25
LV_Forestry
Latvia
Axelz Posted at 5-16 11:25
If you follow John's instructions with the settings on the screenshot provided, it should work.
Mind the resolution, and I noticed that it also doesn't like datasets with a different vertical datum. Better stick to WGS84 GRS80. This shouldn't matter because MBtiles are 2D but obviously it does. No idea why.
5-16 11:28
Axelz
LV_Forestry Posted at 5-16 11:28
Thanks mine is using WGS84 EPSG:3857 so not 100% the same but does display in the preview, I did change co-ordinate system to the same in the screenshot but behaviour still the same unfortunately.  Will see what DJI say when they have tried my tilesets. Cheers.
5-16 11:49
LV_Forestry
Latvia
Axelz Posted at 5-16 11:49
Thanks mine is using WGS84 EPSG:3857 so not 100% the same but does display in the preview, I have just logged with DJI and provided my files so they can try them out.  I'll see if i can change to the same co-oordinate system you have used and retry in case that were the issue here.
3857 is normal, it's pseudo mercator. To flatten the map. Otherwise it would be twisted.
The idea is to generate the DME in WGS84 without changing the vertical datum. Then you generate the orthophoto, there you will have no choice. If the DME is WGS84, the ortho will be too.
I'm doing the test to make sure I'm not telling you nonsense. So far I've output DME and Ortho in LKS92 LV14 format, neither works. Then the DME in WGS84 GRS80 format, that works. The file is 300Mb.
And now it's the turn of the 1.63Gb ortho and it works too.
I have the same settings as John:
5-16 12:05
Axelz
LV_Forestry Posted at 5-16 12:05
Thanks for trying, I'm using same co-ordinate and export format settings but still crashing when enabling, preview works fine.[img][/img]
5-16 12:11
LV_Forestry
Latvia
Axelz Posted at 5-16 12:11
Thanks for trying, I'm using same co-ordinate and export format settings but still crashing when enabling, preview works fine.[view_image][/img]
So there I am dry. If the preview works but not in the map... I really don't see. Especially since your map is much smaller than mine and the resolution lower.
I suggest you download (the link should be active within 15 minutes, time to upload the file) the map that I used as a screenshot in the previous post and test.
https://failiem.lv/u/6t9z3ckzr
If it works for me but not for you, you can suspect the malfunction of your RC.
5-16 12:21
Axelz
LV_Forestry Posted at 5-16 12:21
Thank you, I loaded your overlay in and it did work.  Appears my problem was i was using spaces in the name.  Once I renamed to remove those the tilesets magically appeared in the view!  Appears to be a bug in the application, hopefully fixed with a future release.
5-16 12:37
patiam
Flight distance : 1061247 ft
Axelz Posted at 5-16 12:37
never, EVER, use spaces in the name or path when doing geospatial work.
EVER.
5-16 15:41
