JJB*
Flight distance : 12260774 ft
Mark_F Posted at 3-22 08:03
If I understand this correctly. I had everything set at default on the controller. When I started it up, apparently I wasn't logged into DJI yet so it started off in Beginner mode. I didnt realize that until I was out about 200 ft. I played with the controller for a little bit trying to set the altitude back to 396 ft. Took me a couple tries, and I think sometime in that process I was able to log into DJI. I will have to look closer at that screen on startup from now on.
I admit, I was BVLOS, which I rarely do. I was wanting to see just how high that mountain peak was ASL. I was at 4200ft ASL at home point. I think I ascended, adjusting the height in the fly app... but the limit is 1600 ft. At that point I was able to judge by the ground that I was about 350ft AGL which made the peak somewhere around the 6000 ft mark, which coincides with the information I had, Basically using this as an education flight to see if I could judge distances AGL.
35% battery will automatically initiate a RTH. I can cancel that. Which I did.
Hi Mark,
No worries about BVLOS, not here to judje other remote pilots. (i will do if flight starts at mid runway at JFK :-) )
First Smart battery requires RTH at 41% batt, distance out 7852 feet.
RTH cancelled, flying back to home....
Second call at 35%, distance out 2625 feet.
RTH cancelled.
Third RTH initiated by you with 22% batt, distance out 158 feet.
RTH into Autolanding wich was cancelled.
Nice flight!
AFAIK the cirtical low battery landing (wich cannot be cancelled) - 10% batt level for a Air2S
Low battery RTH can start at various batt level values, depending distance out and fly height. (as seen in your log)
Touhing the screen can do buggy thinks...flying in active track mnot knowing this....
So mayby this focus error bc touching the screen.
cheers
JJB |
