LT56-DV
Flight distance : 594521 ft
I have DJI's QuickCare on my DJI Drone, and recently sent my Mini 3 Pro for service as one armature felt loose and received another (new or refurbished?) back.
I had no qualms with this replacement, but I notice that the distance and connection with my RC seems to not be as solid. Now to be fair my flights haven't tasked the range as much. However, two days ago I am on Brasstown Bald, high point, One flight with the extended batteries NO problem.
Second, Eveything seemed ok, seemed as if I was facing the drone's direction, clear sky. It was higher than my point -- but when I dipped I went from full strength to red. So I brought the drone back and higher. RC signal stablilized. Tried to spin around and bring the drone in for a final pass and landing and it just went down.
Loss signal no RC connection -- mind you it was closer than the first times it was giving me red warning. My phone flashed one final signal and I knew.. it was down, I saw a flash of blue sky.
Trekked down the mountainside and retrieved it. It was sitting in a low branch, like it had coasted down and not flown into a tree. No damage and not even propellor damage. It was however hanging camera side up caught on a thin branch. Could not connect to it with my remote to produce a sound until I was like 100-50ft away (39-28m)
Took it home pulled all the images. Tried to piece together the flight data. No errors in the logs with regards to connection. It just .. goes.. down.
I reflashed the firmware on the RC and unit. Took it for a test flight yesterday, again seemed ok. Sometimes (and this happened with my previous drone and this one) I will get a slight image transmissions miss where 2-4 frames are dropped and then it picks up. Especially metro I guess RF intereference? However, I am highly concerned with this. I keep trying to find information why it went down in the first place. The "where's my drone" footage on the phone does not even duplicate exactly what I saw (that flash of blue at the end). I do not think I hit a tree, or anything. Last data in the log shows it was going down around .1 mph then 0.0. Super odd.
COuld there be something wrong with this replacement? I do not want to pay (and go without a drone) and then be charged for shipping and some "cause" that is a attributed to a crash that may have been there prior? I don't know. Super nervous about flying this drone anywhere right now though. I have refreshed the firmware on both RC and Drone. Not sure what else and it does seem to respond well. Take off I do a quick maneuver check, hover 2m, f 2m, back 2m, strafe l/r 2m, etc and it seems fine and remain in hover mode with good satellite coverage. Just wondering if I am missing something or if I should do something else to ensure it doesn't fall out of the sky like that again
