DJI Paladin
Hi there. Thank you for reaching out and we're sorry for the trouble. Can you please confirm if you are referring to a battery of DJI Air 2s or DJI FPV? Regardless of this, can you please try to wipe the metal contact pins on the battery or the aircraft with isopropyl alcohol (concentration > 75%) and then check if the issue persists? In addition, can you please try to use a different battery on the aircraft and then check if the error still appears? Please keep us posted. Thank you. |
