Battery count
777 6 2023-3-21
Dark Horse
Flight distance : 175276 ft
I have a used A2s, how do I locate the spot where the battery charge count is displayed? The batteries seem really weak, about 10 minutes max of flight time, some of this may be from the cold temperatures, but I think there's more to the story.
Thanks!
2023-3-21
Sean-bumble-bee
Flight distance : 15997 ft
From memory bottom of the safety minu > battery info
2023-3-21
RobZilla
Flight distance : 1057844 ft
Or if you have AirData account, battery & drone stats listed.
2023-3-21
Dark Horse
RobZilla Posted at 3-21 15:39
Thank you, I don't have such an account, never knew this existed. Now that I do I will have to look them up and see what it's all about!
2023-3-21
Dark Horse
Thank you, I found it! So now I have the charge cycle counts for each battery but I don't know what to do with that information. I'm not sure what a high count is, or what the life cycle of a battery is supposed to be.
2023-3-21
DJI Paladin
Flight distance : 318 ft
Hi there. Thank you for reaching out. We're glad that you already figured out how to check the battery count on the batteries of your DJI Air 2s. Kindly please check the other thread that you posted as I provide information on the said inquiry. Please don't hesitate to reach us if you have other concerns. Thank you for your valued support.
2023-3-21
Sean-bumble-bee
The air data count is based on how many times Airdata sees an increase in the battery's charge level.
How big an increase is required I do not know but it can result in incorrect 'counts' appearing in Airdata if appropriate logs have not been uploaded or perhaps deleted.
I found this when looking for charge counts of Mavic Mini batteries when they were used in the Mini 2.
2023-3-21
