DJI Wanda
Hello, there. Sorry for the inconvenience. Could you please try the method below and tell us your feedback?
1. Do you have any protective case mounted on your mobile phone? If so, it may cause poor contact between the connection cable and mobile phone. Please remove the case and try to connect them again.
2. Please try to disconnect and reconnect the USB cable, and then check whether the remote controller is connected to the mobile phone.
3. Restart the remote controller.
4. When using an Android device, if there is a prompt, be sure to tap [OK].
If there is no prompt, please enable USB Debugging on their mobile phone.
Notes:
Please set the Connection Mode to Only Charged. For some devices, |
